OK, let's try to summarise for various options:
Based on playback via Itunes only:
Which OS (XP, W7, latest Mac OS), computer (typical netebook, MacMini, AppleTV) will give what signal (bits, sampling rate, bit-perfect or not) out via which output (USB, optical)? (mentioning any necessary tweaks/settings). Could you please post any corrections and additions and I will then edit this post to be a good summary on the subject.
Win XP: Netbook: USB - no bit perfect possible with itues, max bits - 16, max sampling rate - 48kHz
Win XP: Netbook: optical - normally no optical out on netbooks
Win 7: Notebook: USB - bit perfect possible with itunes????, max bits - 16, max sampling rate - 48kHz
Win 7: Notebook: optical - SPDIF rare, but, if present: bit perfect possible with itunes????, max bits - 16?????, max sampling rate - ?????????kHz
Mac: MacMini: USB - bit perfect OK provided itunes volume is set to 100%, cross fade off, sound check off, max bits - 16, max sampling rate 48kHz. + edit + See post from Craig M. below for more details.
Mac: MacMini: optical - bit perfect OK provided itunes volume is set to 100%, cross fade off, sound check off, max bits - 24, max sampling rate 96kHz. + edit + See post from Craig M. below for more details.
Mac: AppleTV: optical - bit perfect OK provided itunes volume is set to 100%, any settings????, max bits - 16, max sampling rate 41kHz
Mac: AppleTV: USB - no digital audio out via USB on Apple TV
MacMini gives the best signal then?
Would appreciate your input.
