Cleaning an LCD screen?
Charlie Jefferson
229
What's the best way to clean an LCD screen?
My young sons paw prints have found their sticky way onto the bottom of the screen.
Only just noticed it when the sun shone onto the blackened screen when the TV was switched off. The hand prints seem smeared onto the sceeen.
Anyone any top (non-Viz) tips?
Bouchard smear free Glass & Modern Surface wipes. I got them out of a PC repair shop and they are very effective on my LCD, PC screens and the Nintendo DS.
Use a microfibre cloth. They're available from Currys, Comet etc and most supermarkets too. Avoid using any kind of solvent, detergent or other chemical cleaner. They can cause damage by either removing or contaminating surface coatings.
beaverme:Use a microfibre cloth. They're available from Currys, Comet etc and most supermarkets too. Avoid using any kind of solvent, detergent or other chemical cleaner. They can cause damage by either removing or contaminating surface coatings.
Absolutely spot on and exactly the advice we give our customers. Poundland do a good line in microfibre cloths.
