Classical music system to play at low volume
Hi! I'm searching for a system capable of playing good sound at low volume. I found linstening to classical music in headphones quite fatigating even with some crossfading. My system, with the reference 20 infinity loudspeakers doesn't manage to give good sound at low volume so I would be glad to know yours opinions on how a i can solve my problem ( if possible) spending about 700 pounds.
Thank you
Paradoxically, what I've found is that in
order to play classical at low volumes you actually need a powerful amp. Otherwise you seem to loose all the bass and
dynamics. Try to audition the most
powerful amp that you can afford. Perhaps
try and get one of those big MF jobs second-hand.
