chord signature jumper cables.
gbhsi1
237
I currently use kimber 4TC jumper cables but thinking of getting the above mentioned. Is it a worthy upgrade? Has anyone had some experience with using the above. I am using epic twin speaker cable.
If these are jumpers on the speakers (not amp), unlikely you'll notice much difference for such a short run. Just get a 10cm extra cable and cut into 4 small pieces and make jumpers yourself.
I used these on my B&W 685's and honestly it did nothing for me.
