Chord Odyssey biwire vs Chord Epic single
I am currently using Chord Odyssey biwire. For aesthetic reasons I want to change to a darker coloured speaker cable and ideally a thinner one. Is a change to Epic single wire plus some jumpers likey to be acceptable?
Marantz PM7001KI, SA7001KI, Clearaudio Performance, Ortophon 2M, Monitor audio GS10
hifibob:
The Epic is better, without question. It's not thinner though..
Yep much better but not thin either. You could always spray the cable you had with a paint can as you could even match it to the carpet etc then ;-)
Thanks for the response. I was thinking that it would be marginly thinner if I went with the single as opposed to bi wire cable.
What? The Epic is no thinner than bi-wired Odyssey? What kind of boa constrictor are we talking here?
I have just found the diameters from the Chord website
Odyssey 2 is an 8mm diameter twisted pair twin conductor cable for single wiring
Odyssey 4 is a 13mm diameter bi-wire cable.
Epic Twin is an 11mm diameter twin conductor cable for single wiring
Epic Super Twin is a 16mm diameter four conductor cable primarily intended for bi-wiring.
So epic twin is not much thinner than odyssey 4. I might still give the single wire epic a try.
If you do go for the epic, let us know what changes in sound it brings from the oddy cable.
