Chord Epic Twin vs Epic Supertwin vs Atlas Hyper 3.0
I was down to a short list of 2 cables the Chord Epic Twin and Atlas Hyper 3.0 then i have been offered a good deal on some Supertwin has anyone compared the Twin & Supertwin? The Hyper 3.0 is cheaper and seems fairly well regarded but im leaning towards one of the Chords as ive been told will work well within my setup. just wanted to see if anyone had an opinion on these. Thanks.
I've heard the Epic and the Hyper and they are really at opposite ends of the scale tonally. So it totally depends on your system/room/ears as to the best cable for you. I'd definatley try to demo before spending that much wonga...
jules.
Just to update i went for the epic supertwin in the end as i was offered such a good deal for the 3 lengths i required, i found it an absolute nightmare to bend to fit in the back of my cabinet etc but the sound has really improved the cable at full price is obviously significantly more expensive than the qed silver anniversary bi wire i was using but has made a very noticeable difference so im pleased.
