CD player to amplifier connection
GazW649
15
What is the best cable to connect my CD player (cambridge audio 640 V2) to my amp (Nad 352) ?
You need a simple pair of analogue interconnects for this one. May I suggest the excellent Atlas Equators? £48 for a metre and they sound brilliant.
Are these the best analogue interconnects? Do they make that much of a difference to sound quality?
I'd suggest either Van Den Hul 'The Name' or either the QED Qunex 2 or 3 interconnects.
All very good and for less than £50.
check out e bay.Second hand cables are already burned in and you can often get some very good ones on e bay for a song. I got my chord chorus for £78.Bargain. Thats maybe a little expensive but for £40-£50 you could get a £80-100 rrp cable.Just be careful to check out the feedback and condition.
