cd player question
markyboy156
203
:) hi i have the onkyo 5009 i want to buy a cd player to connect to the amp i want the very best sound quality in what the amp can do i want the perfect match would the
Roksan Caspian M2 CD be the trick or is there any other suggestions thanks need help asap please :)
richardw42
299
I wouldn't spend anywhere near that much, but buy a cheaper but capable player and connect to your Onkyos DAC. Mind you if you have an existing BDP/DVD they might be good enough.
The only real way is to loan a high end player and compare it with your own amp and speakers in you own room.
