Cassette Tape to HDD?? Yes Cassette tape...
Hi
I have about 20 tapes I MUST keep and worry they will go the way of all tapes.
I have a tape deck (removed from the hi fi and in storage) I have a HDD. Is it a simple matter of connecting tape via RCA to Line In on my soundcard. (Asus D2X). Or do I need something else.
Should not be an expensive solution as it is only for 18 - 20 tapes.
Think the above *should* work. Will it?
Thanks in advance.
Hi
Yes that's pretty much alll you need, apart from some software to record the tapes - if you don't have any I recommend downloading Audacity. I got very good results doing exactly what you're proposing.
Thanks very much. I will do as I have used Audacity before.
Nice, simple cheap solution.
Good luck with your question, I looked but could not advise unfortunately.
