Cartridge for Planar 3
Have had current system for many years (Rega Planar 3/ RB300/ Nagaoka MP11 Boron - Nain Nait - KEF Q4 - Arcam Alpha 5). I would love to replace the sylus on the MP11 but the Boron version seems unavailable so I guess I need to source a new cartridge. Ive seen Ortofon and Goldring mentioned as good choices does anyone know if they get near to the Nagaoka for all round musicality ? If Ortofon and Goldring would be good choices which models in particuar ? Thanks for any opinions.
There is a supplier that recommends a replacement with the MP20
http://www.musonic.co.uk/mp11-original-boron-stylus-use-mp20-stylus-p-17682.html
It is £180, but you'd probably spend as much for a Goldring or Ortofon.
The arm you have will handle any MM from those makes, the only limit being your budget. For example, an Ortofon 2M Blue is a bit cheaper, and the Bronze about £100 more.
Guys. Thanks for responding. Had a few PC problems so wasnt able to catch up until now.
