Canton DM55 remote control problem
rallatt
We're onto our third remote control with this DM55 (Remote is RMB50546) and for the third time we've got an unresponsive DM55. Batteries are fine - the power light flashes red when I attempt to power up the soundbar. There doesn't seem to be any support from Canton (that I can see) and wondered if anyone else has had this issue?
Batteries are fine
...and presumably the normal 1.5 volt types (as opposed to 1.2v rechargeables).
In which case, after 3 new remotes, your attention must be on the soundbase itself.
If you give up trying to contact Canton, maybe take it to a repairer - preferably one that will provide free estimates.
Or, nothing to lose by opening the thing up yourself and having a look - at and around the infrared receiver.
Check that the receiver itself is in a position to clearly receive the remote's signal - and that there's no dust between it and the front window.
Maybe there's some identification on it (or its PCB) to allow you to obtain and fit a replacement (using only the minimum of heat necessary from a soldering iron).
Hi there I had the same problem only a few weeks ago the canton dm55 stopped responding to its remote control after a lot of attempts the system would come one
everything works fine volume input Bluetooth but again same problem it won’t switch off after afew attempts it switches off.
I contacted canton in Germany they replied and forwarded me details of some one in uk who could help I contacted them and explained what was happening to the system they replied it seems like the power supply board needs replacing it would
cost £180.00 Plus p&p
It's an old thread you're replying to @Unsworth.
With regard to your issue, £180 is over half the original cost of the Canton. Maybe the money would be better put towards a new soundbar/soundbase? 🙂
This is obviously months on but I have had two Canton soundbases & struggled with the remotes for both.
I have just (24h ago) taken delivery of a Chinese compatible remote (from eBay) & it is working flawlessly. I think on the evidence so far the remotes are the problem; I am keeping fingers crossed it is solved for me.
