Cantilever TV stand.
PINK MOON
34
Im looking for a catilever TV stand for a 42" plasma. Ill be using a centre speaker on the top shelf. Yamaha 667, Sky HD, playstation 3 also a cd player and probably a stereo amp. Im aware of the Atacama Equinox AV TL, but im just not sure its big enough. I have found the Atacama at £268 online, so I dont think I would be willing to pay much more than that. Any ideas?
http://www.allcam.biz/catalog/popup_image.php?pID=584
A lot cheaper, not the greatest stand in the world but it does the job, I picked one up a while ago as I needed something cheap for my bedroom.
Probably get everything you list on there.
Not sure if you have the space but i use the ATACAMA EQUINOX AVI TL AV RACK WITH INTEGRATED 41-46 INCH FLATSCREEN MOUNT which i got from ebay for £120 yes i know what your thinking ...no way as they used to cost in the region of £399 when they came out but the guy on ebay listed it incorrectly as a TS then update the info near the end of the auction to a TL so i put in a bid for £150 in the final seconds and won it for £120.
so i use this tv stand with my centre on the top shelf and sky+hd box on the bottom i also purchased a hifi rack (make is soundstyle from ebay for £50 which has 5 shelves
holds my onkyo receiver, marantz cd player, sony dvd recorder, pioneer blu ray player and top shelf for my ps3 slim 320gb and it looks very neat and organised.
hope that helps
salparadise:
Hi, how stable are the shelves, particularly the top one, as its a reasonably big centre speaker that would go on it.
I have a Q Acoustics 2000 centre sat on the top shelf along with a 50inch plasma and have had no stability problems, along with what has already been mentioned I have an onkyo receiver, ps3, atv and blu ray player all sat on the unit and have had no issues whatsoever.
