Can I use a AV receiver instead of AV processor?
Judge_death
for years I have been using a Yamaha DSP E500 to run my home cinema connected to my Cyrus 7 amp to run the front speakers.
I need to update my home cinema so that I can have a unit with multi HDMI plugs and other latest features.
what I would like to know is that am I restricted to using the same AV processor system which has very little choice, or is their some way of using a dedicated AV receiver somehow?
i can spend up to £500
I will be running my PS4, PS3, SKY, Apple TV through the system.
music remains my main passion so I'm not comprising on that front, any unit I buy must work around my main hifi amp.
many thanks.
his dudeness
86
Judge_death said:
many thanks.
a av amp with pre outs will do what you need,you will just be using it as a processor,pre amp,not sure if you will get pre out on that budget.
Frank Harvey
567
As long as the AV receiver has the relevant pre-outputs you want to use, you can use any you like. Pre-outputs tend to be more limited on budget receivers nowadays, so do double check.
richardw42
299
Peter Tyson were doing the Marantz SR5009 for around £300+.
Im using it with 6.1 active speakers from its pre outs.
Yes. Currently £329 on their site.
