Can i bi-wire using speaker terminal + one un-stackable banana plug on top?
RobinKidderminster said:
on top? Use one wire wound on terminal and one plugged with nana plug ofcourse.
Thank you Robin for the answer, but i am not sure if i did explain it well enough.
So i was talking about connecting the wire on receiver side, not on speaker side. So that one wire wound on terminal and other with the banana plug goes sort of on top of the same terminal.
Sorry for my confusion 🙂
My pleasure. Or use a spade. Or some nana plugs allow two cable entry. Depends on cable and required neatness. I dont biwire but if I did I would use spade & nana.
