- Aug 10, 2019
- 2,556
- 5
- 0
I am just about to purchase new home cinema equipment for a room in my house, but any tips or advice would be appreciated - I have signed up to see what you recommend?
Amp - I am torn between the Onkyo 608 or the Denon 2311. For a budget of up to £470.00, what do you recommend?
Sub Woofer - I am thinking about the B&W 608, but will probably pay the extra for the B&W 610. For a maximum budget of £450.00, what do you recommend?
TV - I need a 46/47" screen so I was thinking the Sony 46EX713? For a budget of £900-£1000, what would you recommend?
Speakers - I am opting for in wall and in ceiling speakers. I was thinking 2x integrated wall speakers on either side of the TV, 2x integrated back ceiling speakers, then a centre speaker either in the ceiling above the TV or below the TV in the wall. Not many ceiling or wall speakers are reviewed, so I have looked at Kef, B&W and Monitor Aaudio. At the moment I am leaning towards Monitor Audios - 2x C265FX rear effect speakers, 2x W265 wall speakers and then another 1x W265 as the centre in wall or 1x C265-LCR as the centre in ceiling. Any advice would be appreciated
2nd Zone - Off the amp, I am also looking to run 2 or 3 speakers in another room. These are just for music. I have been told to either run 2x mono speakers or I could run 3x stereo speakers in a series/parallel config?
Overall - I would be open to advice on any of the above and anything I need to consider in relation to audio or quality limitations? Along with this kit I will be running a Sky HD+ box, BlueRay DVD and Games Console, so best audio is required within budget.
Thanks in advance!!
Thanks in advance!!
