Tarquinh:
shooter69:I recall you was going to check out a 5 pin Din to RCA some time back!How did you get on??Was it a positive result?Too early for Chebby, the alarm hasn't gone off yet
I picked up a converter from my local electronics store. However, Naim may use different pin outs on their DIN plugs in which case you'd need a Naim dealer. Otherwise, I'd imagine Maplins would have them.
I was thinking Hi line.
But i'm not sure how the config would work?
I understand Din to Din and RCA to RCA but Din to RCA surly that defeats the object of a Din in the first instance?
Hopefully Chebby can shed some light.......
