Hi BB,
received the following from AIX:
The disc is fine...what you are (or aren't hearing) is the DTS legacy stream
and not the DTS HD Master Audio stream. I forced the downmix coefficients to
make the audio virtually silent because DTS does a downmix and not a
separate embedded track like Dolby.
You need to make sure your A/V Receiver is set to the right number of
channels and is actually accepting the DTS HD MA track. If it's not it will
revert to the legacy format...with no sound output. The fact that there's
not sound is because you're hearing the legacy track.
Edit:
re tried the disk, If i turn the volume up to 0 i can hear the test at the same volume level that the other tests do at -35.
