If i want Freesat i will need to take the signal from a neighbours dish,i think that this will mean changing the LNB to at least 2.The other possible problem is that the cable run will be approx.35/ 40 mtrs.
Will the signal degade a lot over that sort of distance & be an issue.The reason i'm thinking about it is because i've read that the HD picture through the dish is better than the aerial.As i'm thinking of getting the Panasonic G20 which has freesat & Freeview Hd tuners i thought i'd ask the question before doing anything about it.
The SD freeview picture is fine,no problems
