singularity6
I had a Songbird, which I liked at first.  The lack of gapless play was annoying, so I bought a WiiM Mini.  It's much better.
			...anyone who's spent £1000+ on a streamer will be certain that this couldn't possibly be as good.Over on ASR, they measured the Wiim Mini and deemed the toslink out completely transparent so if you hook it up to your favourite DAC, you are only limited by the rest of your system in terms of sound quality.
Seems like a good cheap option for a streaming transport if you have a separate DAC or an integrated with it's own DAC.
Good to hear, and that's exactly how I use it, with a DAC integrated. It's also interesting to take analogue interconnects out of equation.Over on ASR, they measured the Wiim Mini and deemed the toslink out completely transparent so if you hook it up to your favourite DAC, you are only limited by the rest of your system in terms of sound quality.
I have it set to 24/196. Does it upsample if I just play 16/44.1 files?There's only one thing betraying the Wiim Mini's budget roots, and that's the manual bit depth and sample rate setting. This should be automatic like any other hifi streamer.
I will suggest this change to Wiim.
Sometimes TV's (or cable boxes) have a volume limiter on pcm out. You might want to check that.Here's the thing, on my soundbar Tidal sounds better streamed from my TV than the Wiim Mini. Sad but true.
Since my node 2 died I ordered the wiim. I think it has really incredible value for the price, it's quite insane, especially considered the many possibilities. For example better than airplaying over an apple TV.
However I bought it after reading that people found it comparable to the node. I am unimpressed when I compare it to the node. Timing, detail, separation, transients, are better on the node. There's more energy in the music on the node, it felt much more "alive". As you would expect for several hundred $ difference...
The wiim, as was the node, is plugged into a LPS powered chord mojo, into a CXA81 and LS50 original version. Maybe you can't hear a difference with more forgiving speakers. The kef are very revealing.
