Question Budget setup upgrade suggestions?
Mreim769
Hello everyone!
Long time listener. First time caller. Just wanted to quickly say how much I appreciate the posts and responses within the community. I've used the heck out of these forums without ever having needed to post anything myself. Until now!
I've slowly accumulated a mishmash of audio equipment over the years and I'm finally looking to make a relatively big purchase of possibly something new (or new to me). Where to start is the biggest question I have right now as I would slowly like to get into better equipment. Here is what I have:
-Dual 1219 (AT11E)
-Schiit Mani 2
-Denon AVR-3313CI (phono input doesn't work hence the Mani)
-Dahlquist QX10s
-Beyerdynamic DT 990 pro 250 ohm
-Schiit Vali 3
-Schiit Modi (1)
I primarily listen to vinyl over speakers so I would say that's probably the direction I'm going to focus my upgrades on. I just wanted to include everything in case I'm doubling up on something that I don't need. I'd like to keep my budget at or below $2k (CAD). I think the Denon might be the weak point right now. From what I could see the Rotel A10 MKII ($849) might be a good option as the A11 MKII ($1,099) has a DAC which I already have in the Modi. Whether or not the A11 MKII DAC is a better DAC than the Modi I'm not sure. The Arcam A5 ($1,099) and A15 ($1,499) also caught my eye but seem to be similar to the A11 or overkill for what I have right now but might be worth getting for future proofing. Not sure how the Mani stacks up against the phono in any of those options or if I should be looking at something without a phono.
I like my Dual well enough at the moment but I know it will be the weak point if I upgrade the Denon. A cartridge upgrade might help stretch that one out a bit further too. I haven't really seen a turntable and amp combo that would keep me below my budget if I bought both right now. I don't have a ton of knowledge in the newer realm of turntables but the Technics SL-1500C ($1,599) seems to be a solid upgrade candidate to jump into the modern era of turntables.
Anyways, my apologies for the rambling. Where do you think my $2k would be best spent at the moment? I think my speakers are probably the highlight of my equipment right now but I might be wrong. Ideally everything would get switched out further down the line. I appreciate any input as I've done a bit of homework but I don't have a ton of experience and might be missing something glaringly obvious.
Given you listen to vinyl, I'd start by replacing the cartridge with something like an AT95ML. If you are happy with the Dual, then keep it. The 1219 is a bit of a classic. A cartridge upgrade will be a better investment than replacing the turntable, at least for now.
Replacing the AV amp with a decent stereo amp is likely to be a good move but I know nothing about your speakers, other than people seem to like them. If the speakers are warm sounding you probably want to avoid a warm sounding amp. That said the amps you list are decent choices.
For the sake of sanity, I'd use the onboard DAC and pre-amp and flog the separates. (Does the Rotel A10 have a built-in DAC?)
Basically my vote would be a new cartridge and amp. If you can audition amps then that would be a good thing to do. Personally, I'd narrow down to the A11MK2 and the A5.
