- Aug 10, 2019
- 2,556
- 5
- 0
I am new to Hi-Fi. Am looking for a budget Hi-Fi system.
Have short-listed two speakers - MS 902i and Wharfedale Diamond 9.1.
Although i am getting the 902i at half the price of 9.1.
Also i was looking for either the PM6002 or the CA 540A v2.
I had thought of the CD6002 earlier. But then found it a bit bright with the PM6002.
Also have a very tight budget so cancelled the plans of buying a CD player for now.
My system will also be used for movie watching so was thinking of buying the 540D DVD player which could also be used for CD play for the time being.
I listen to all kind of music - Rock, Pop, classical, a lot of trance, James Taylor, Blues, Jazz, etc.
So the following are the questions that i would request everyone answer for me?
Q1) Which one do you think is a better speaker - 902i or 9.1, & a better value for money considering the price that i am getting them at?
Q2) Do you think that the 540D will suit the PM6002?
Q3) Also which amp do you think will suit the 902i better - the PM6002 or the 540A v2?
Q4) Also which combo will be better - PM6002/540D or 540Av2/540D? (considering that the 540A is supposed to be bright which might get nullified by using the PM6002)
Thank you in advance.
