Budget CD Player
Hi there,
I'm after a CD player to hook up to my system, which comprises:
Cambridge 540A, Monitor Audio BR2s
Probably looking to spend £150-£200. Obviously, having trawled through the WHF website, I can see which models are the best rated in this price bracket, but which do you think would go best with my particular set-up?
I guess my main options are Cambridge 340C, NAD C515BEE, Marantz CD5001 or 5003, Cambridge DacMagic, or Cambridge 540C.
Any advice greatly appreciated.
Cheers.
I'm currently using an iPod, connected through a Belkin cable to the back of the amp....
Thanks for that.
I'll bear it in mind....
A level above where I was aiming, but as you point out, it's in budget still.
