Do these exist. I know Marantz do a higher level SA8005, but are there any more affordable type units
muljao said:Do these exist. I know Marantz do a higher level SA8005, but are there any more affordable type units
muljao said:Sorry, I should have been more clear. What i mean is a cd player with a b type usb dac that can be used to plug a computer into and use the cds dac as the decoder
I'd consider 300 pounds budget in this regard
muljao said:The normal usb you see on the front panel generally can play files off a usb stick and/ or can be apple friendly. It seems you get a back usb b type with usb dac labeling for one that plugs into a laptop or PC usb and takes over the soundcard. The marantz sa8005 does this and is a SACD player also, I'm looking for the function but not the price
Al ears said:muljao said:The normal usb you see on the front panel generally can play files off a usb stick and/ or can be apple friendly. It seems you get a back usb b type with usb dac labeling for one that plugs into a laptop or PC usb and takes over the soundcard. The marantz sa8005 does this and is a SACD player also, I'm looking for the function but not the price
So something less than £599 eh? Sorry cannot help.
muljao said:Al ears said:muljao said:The normal usb you see on the front panel generally can play files off a usb stick and/ or can be apple friendly. It seems you get a back usb b type with usb dac labeling for one that plugs into a laptop or PC usb and takes over the soundcard. The marantz sa8005 does this and is a SACD player also, I'm looking for the function but not the price
That price is after really dropping. This was nearly twice that not so long ago
