Blue Ray analogue out to AV receiver
fayeanddavid
191
Now is the time for the next step, the Blue Ray player, either the new Sony BDP S760 or the OPPO BDP 831
Choice is also limited to players with analogue out, fed into my Yamaha RX-V2700, AV speakers are KEF Q7 (bi amped), Q2DS surrounds and iQ6 centre, sub is a REL Storm III
Question;
Just how good is analogue out (compared to HDMI), and decoding at the Blue Ray player, if it is "flawed" is it seriously noticeable in "normal" domestic environments, cosnsidering to change the receiver would need another £1,500 or so (gulp), difficult one as the spend on the 52W5500 has only just met with full approval!!! ?
Would really appreciate opinions from users on this.
What...............lack of interest or is it that nobody has analogue out to their AV amp from their BD player??
C'mon, please tell .................even if I am the only one interested
Pretty please.
The "flawed" comment refers specifically to the Oppo player, rather than BDPs in general, so you're looking for someone who a) has bought the Oppo (which for the 831, is nobody, so you're after someone who got the 83 import) and b) is using the analogue outputs.
I'd guess that's a pretty small field to be honest, which might explain the lack of answers.
The Sony 760 player is pretty new as well, so again the number of users is going to be somewhat limited.
I think the common consensus is: If you're decoding on board the BD player, the quality of the BD player becomes more important than if you were sending the 'raw information' via HDMI to a receiver which decodes.
I've not decoded on-board BD myself (my S350 lacks multi-outs and my 875 can recieve and decode HD audio, so I've not seen the need even if I was able) I have seen posts where people have done comparisons between the two methods and they tend to favour decoding by the receiver as being marginally 'better'. Not that BD decoding was bad in any way, but not quite as good. Cheaper too, as you only need 1 HDMI rather than 3 or even 4 pairs of analogue interconnects.
I'd stick to using the analogue outs and save that £1500!!
Hi Big Chris,
Slightly off topic! I see you have an Arcam CD192. I just wondered how you rate it. I currently use a Cyrus Discmaster 8.0 for CD playback.
Cheers.
Bemused:
Hi Big Chris,
Cheers.
Love it. Only got it this year after having a CD72T for 7 years. Major leap forward. More of a leap forward than changing my amp from an A65+ to an A85 was.
Hi there,
Had exact same issue.
In the end I bought a Panasonic DMP-BD55 to supplement my current setup
My findings with using this player are:
- 7.1 and 5.1 analogue output works great for Blu-Ray
- Also acceptable for DVD - but find that my Arcam DVD does a noticably better job
- CD playback is horrible - again against my Arcam DVD
- Setup options (subwoofer cut-over frequency, speaker delay etc.) is not as good as the Arcam. These are again sufficient for Blu Ray, but not acceptable for CD with Subwoofer etc.
So check that you get all setup options in the player you choose. The amplifier will be a volume control and nothing more
TR
Roten,
thanks for the info, pleased that someone else has the experience, and Yes I'm aware of the set up process needed through the Blu Ray player, thanks again
As for dvd and cd play back do you then use the coaxial or optical outputs to the Arcam?
Regds
I have analogue only, as my amplifiers don't have any decoding what so ever (see signature)
I therefore must leave all setup and processing to the players
TR
