Blu-ray ... DTS/DD v DTS HD/DD HD
I am looking into buying my first blu-ray player and have a few questions...
1. Can a blu-ray disk/player output DTS/DD (old format)?
2. Is there much difference between DTS/DD and DTS HD/DD HD?...therefore is it worth buying a blu-ray player with decoder.
I am looking at either...
Panasonic DMP-BD35, Sony BDPS350/BDPS550
Not sure if I can afford the Panasonic DMP-BD55
Are there any other options?
Other options - PS3, just ordered mine last night off amazon. I hope it lives up to the hype!
chris_uk:1. Can a blu-ray disk/player output DTS/DD (old format)?
Yes.
chris_uk:2. Is there much difference between DTS/DD and DTS HD/DD HD?...therefore is it worth buying a blu-ray player with decoder.
In my opinion, yes. But do you have an amplifier which is able to accept and decode the HD signal? This could be a crucial factor on which Blu-Ray player you choose.
professorhat:In my opinion, yes. But do you have an amplifier which is able to accept and decode the HD signal? This could be a crucial factor on which Blu-Ray player you choose.
Yes...my Amp has 5.1 external decode input...I can't justify replacing my amp, I know its around 9yrs old and there are some much better amps out there but for £400+ money...I will wait for it to go wrong.
soulstyle:Other options - PS3, just ordered mine last night off amazon. I hope it lives up to the hype!
I have ruled out a PS3, because I have a XBOX360, and a dedicated blu-ray player should be better than a PS3 and will likely have a decoder options, which the PS3 does not have. If I got a PS3, I would need to replace the amp to get DTS/DD HD...not sure if the PS3 have all the HD audio codec supported.
Panasonic DMP-BD35 (£190ish), Sony BDPS350 (£160ish)...good prices but no decoder..hence the question above
Sony BDPS550 (£210ish), good price for the decoder, not sure if the Panasonic DMP-BD55 (£340ish) is worth an extra £130.
I think I am drawn to the Sony BDPS550 because of the decoder and price... Has anyone found the Panasonic DMP-BD55 for less than £340?
Chris
If you're keeping your amplifier for the time being and want hd sound formats you need a blu ray player with multichannel analogue outs. The Sony 550 has them but not the Pana 35 nor the Sony 350
BlueGeoff:
hi, where can you get the pany for £190..
only seen it for over £200
cheers
Amazon
mattjax05:
Chris
Absolutely. As to whether the Panny 55 is worth the extra over the Sony 550, WHF obviously think so as both got 5 stars at their respective prices (if the Panny didn't offer the value over the Sony, it wouldn't have got 5 stars). It also won Product of the Year for 2008 Blu-Ray players...
However, the only way to tell whether it's worth the extra for you is to go and have a look at both.
chris_uk:
I've said this before on here but I am more impressed with the increase in audio than of the picture - you kind of expect raw 1080p is going to look brilliant but the sound is astonishing. PCM and DTS HD Master audio especially.
