I'm having a problem with my Tannoy Custom F1's connected to a Denon AVR-1908, they actually have a freq. range of 55Hz-20KHz, but audyssey sets the fronts to 150Hz and the center and rears to 90Hz. Why would this be?
Currently, i've manually changed them all to 90Hz, if i use the audyssey room eq setting will doing the above have a negative effect?
I used the supplied mic on a tripod which was then placed on the main listening position seat. The mic position was higher than the back of the seat. I took 6 measurements.
Should i be using the audyssey room eq setting or leave it to off? Whats the difference between the various room eq's? audyssey, audyssey flat, byp, etc?
BTW, when the audyssey setup is running, are the measurements only taken when the weird noise is coming from each of the speakers or also when they're quiet?
Cheers.
Cheers.
