I've recently invested in some Arcam kit (SA20 Amp and CDS50 CD player with streaming capabilities) and have wanted to stream Tidal (HiFi/FLAC) to it. Although Arcam have their own Music Life App which lets you do this natively from within the app, the experience is poor (app is a bit flaky, the interface is not as good as the Tidal app etc...). Ideally therefore, I am looking for a way to stream Hifi music from the Tidal App straight into my equipment without having to use Musiclife. I can stream from the Tidal App using Apple airplay but I believe the limitations of Airplay mean that I won't get better than 320kbps quality sound (certainly it sounds that way when you listen to music streamed via Airplay v/s via Musiclife) - so no benefit from the HiFi subscription. I was wondering therefore if anyone out there knows of a better way to do this ? I guess I should also add that I have an iPhone so some of the Android Apps are obviously no good to me ( I gather there are one or two apps that work well but they don't have Apple versions). Ideally, I either need a bit of hardware that plugs into my Arcam but talks directly to my Tidal App on the iPhone (or can talk to Tidal directly) or an App on my iPhone that replaces Musiclife . I am sure someone must have. cracked this ??
