I have the Wharfedale's 9.5 and 9.1, The 9.1's are a great match IMO, for both music and movies, I would go for 4 9.1's and a CS if you are not looking at very big speakers or there is the option of the DFS (Dipole) which are easily hung to walls, the 9 series are much cheaper then the 10 and there is no great difference, and on a budget it will sound great just add a sub then.
Hope it helps.
