Best bookshelf speakers for £100 on Amazon uk
davidb2002
6
I've got £100 of Amazon vouchers to spend and I want to get some good speakers without going over £100. What sort of things should I look for and can anyone recommend any? They will be plugged into a turntable only.
M-Audio AV42 Active
look about your best bet, they seem to be active, many others at this price point are powered. You will need a phono pre-amp unless your turntable has one built in.
I was looking at these
Blaupunkt BT 105e - speakers - wireless https://www.amazon.co.uk/dp/B00D41RNMA/ref=cm_sw_r_awd_ZJCGvb5AX2HJZ
https://www.amazon.co.uk/dp/B00D41RNMA/ref=cm_sw_r_awd_ZJCGvb5AX2HJZ will I need a preamp even though these are powered and have left/right inputs?
Don't like the look of them , no reviews and they look like plastic cabinets. The ones I showed you the previous version has many good reviews, although some have had problems which I guess is to be expected for £100. Yes for turntable you will need a phono pre-amp as the signal will not be loud enough.
