hi folks , im soon going to be getting an amp and speakers , i was going to get a soundbar ,as my tv is in a corner , but i think ill probably end up wishing i had real 5.1 surround , so the tv will be moved in front of a window , to allow for speakers either side ..
i currently have a humax foxsat feeding my 46g10 , and a sony bd363 , the humax is doing the upscaling as its better than the tv , now i am aware of the various 5 star amps in budget , denon 1910 , etc , and as i dont require houseshaking sound , im sure the denon or something similar would be fine , coupled with a good speaker setup , which ill seek advice on when i have the money , im buying the amp first ..
what im hoping is that i can find an amp that can take the 576 signal from the humax , and do a better job of upscaling it than the humax can , before sending it to the tv , does anyone know of an amp that can do that ?? while also being good enough to power a decent speaker setup , which im aiming to spend around £700-£800 on ...
i may spend a little more if there is an amp that would really improve upon the humaxs upscaling , anyone ?? thanks ...
