Best 37inch TV. help please
try these...
http://www.soundandvisiononline.co.uk/listview/index.asp?strSearch=37px70
They deliver nationally, but you will need to buy a stand also. The stand used on the 42" is the same as the 37" PX model, so that should make finding one slightly easier. You'll need to budget about £100 for the stand, unless you want to wall mount. This model also comes with a pedestal stand as an option, but I think these are rearer than hen's teeth in the shops right now.
http://www.amazon.co.uk/exec/obidos/ASIN/B000QEY7Y0/interactiveda3044-21
Hope this helps..
just realised I gave you the wrong model info...
http://www.soundandvisiononline.co.uk/moreinfo/index.asp?product_id=13917
forget about the stand info (its for the other model as well).
Hope this helps again
