Welcome to the forum.Hi.
I would like to know why there isn't a Cambridge Audio speaker in the Best of 2021 list.
Alberto
No.Welcome to the forum.
Is there any reason you think there should have been?
I suppose only the editors of the list can answer that. Are you considering buying some?No.
I'm not an expert in audio peripherals but I'm curious to know if Cambridge Audio speakers are out of this list because they are worst than the others or if there's another particular reason.
from what I have read they are not bad and certainly not the worst speakers for the money but obviously WHF think there are better speakers available.No.
Yes, I'm evaluating Cambridge Audio and ELAC, mainly.I suppose only the editors of the list can answer that. Are you considering buying some?
I don’t think the magazine has tested any for a few years. It looks like the manufacturer has focused more on their electronics, which as you know are very well reviewed.Yes, I'm evaluating Cambridge Audio and ELAC, mainly.
It's the first time I setup an audio system.
Whilst the opinion of journalists and testers might help you narrow down a shortlist, I think the best advice anyone can give you is that you need to try the equipment in your own environment. It's what you like to listen to that is most important. Make full use of distance-selling regulations to try things out.Yes, I'm evaluating Cambridge Audio and ELAC, mainly.
What HiFi often miss out some obvious products from their 'best of' lists...Hi.
Alberto
There are more brands off, than there are on, most lists Alberto.Hi.
Alberto
I have not heard these Klipsch personally but this reviewer was not impressed with the R-41M.... they will sound bright!Thank you all for the advices.
As I said I'm building my first Hi-Fi system. I bought a Denon AVC-S660H.
I'm looking for 2 front speakers, 1 central and a subwoofer.
At the moment I don't care about rear speakers because I'm not a huge fan of movies effects.
The maximum budget I can spend for those 4 speakers is 1.000 euro.
Looking around I found:
2 x Klipsch Reference R-41M
1 x Klipsch Reference R-52C
1 x Klipsch R-100SW 150 W
Total: 982 euro.
audiosciencereview.com
