oldric_naubhoff
- Mar 11, 2011
- 23
- 0
- 0
CnoEvil said:IMO. SQ may be effected by:
- How successfully the processing / filtering is done.
- To what extent the PC polutes the signal..
- How well the clocking is handled.
- Quality of the power supply.
- How successfully the components are isolated.
all your points above relate to engineering quality af accompanying DAC. it all has nothing to do with any PC. all you need is a DAC with galvanicaly isolated USB input supporting asynchronous data transfer. that should cover your points 2,3 and 5. points 1 and 4 don't need comment in this context IMO. when you have the DAC side sorted then all you need is to make sure your PC outputs bit perfect signal. and that is the hardest thing as PCs weren't designed to stream unprocessed musical data. that surely needs some tweaking therefore IMO PC as a transport is a solution for more computer savvy people. streamers are great for people who want ease of use and least amount of fiddling with settings as possible. I think I now found my media centre PC so will not be getting bothered going the streamer route, which I considered as I couldn't find acceptable looking PC before. higher versatility and flexibility of a PC over a streamer makes the whole decision a no brainer for me. CNO tell me, what will you do with your Linn if DSD dowloads become standard in the near future? something that indeed seems to be happening now?
