The Mozart platform is a module. The dealer can take this out and plug in a replacement.
With most televisions and hi-fi you can not change anything and very rarely they offer mod updates. In the digital world you can't upgrade mobile phones, tablets or laptops. Memory options, capacity, storage are built in when you buy them.
The Apple IIe had replaceable boards. CP/M S100 and the IBM PC continued the idea allowing for a 10 year old system to get hardware and software updates without needing everything replaced.
That is what B&O are aiming at. Some changes can be accommodated by new software but others will need new chips and so the module can also be unplugged and replaced by the user or dealer. In PC terms it is fitting a new motherboard and all the cards and drives to the case and power supply.
Whether this will work and support the speakers in 5 or 10 years time we have to wait and see.
Some owners of the CX50, CX75 and CX100 have fitted the Raspberry Pi with B&O 4 channel amplifier that fits onto the RPi board. The passive crossovers are removed and a full active cross-over parameters selected in software. CX50 work as a stereo pair and the CX100 takes three of the four amplifiers for each drive unit. It turns a quality speaker into a new steaming active speaker. So they have a history of making some products get new advanced updates.
