I'm the proud new owner of the Abrahamsen v2.0UP amp and DAC II. I had to buy interconnects and as both have fully balanced circuits it made sense to connect them via XLR than RCA.
A little searching on the internet showed that a 50cm pair ranged from about £10 to £5,250, with most band names £150+. On the forums here a number of people thought that Neutrik plugs and Van Damme cable were as good as you need for such a short length. In the end I chose the Van Damme STARQUAD Balanced Cable with Neutrik Gold XLR to XLR Microphone Lead from designacable and they cost £25 including delivery. They arrived this morning and look very well made, so far so good.
The result, definitely much better than the RCA connections. The RCA is software sounding so clearing loosing some detail. I should add that my RCA cable cost about a fiver and is about 3m long. Not a fair comparison I know but it does show that the cable makes a difference. Unfortunately I don't have a good set of RCA's to compare but if someone wants to send me one then I will give it a listen the post back. 🙂
Anyway, just thought I would share my experience, if it help someone then it was worth it.
