balanced connections
last day of work and then 2 weeks on olydays in sardinia lostening to my dads pathos if he asent sold it yet
[quote user="sex"]is there such athing as balanced y adapters to byamp[/quote]
I'm having a pair of Anthem 2's made in a Y format(havn't asked how much though,I'll sort that when they are installed)
it seems the y shaped cables for bi-amping could be better for sound quality......a sealed bi-amp box with 1 input and 2 outputs was better to my ears.
[quote user="Andrew Everard"]
What, like these you mean?
[/quote] you are the man but now the question raises balaced or unbalanced connections wats the difference and the pros and cons please be so kind to explain
Very simple version - most conventional connections use the main core for the + conductor and the - as the shield, whereas balanced connections have separate + and - conductors, each with their own shield, hence the third pin.
They thus offer better interference rejection, as anything picked up on the + will also be picked up on the -, thus self-cancelling.
As I said, the very simple version...
this meand that thy give less interference but not explicitly better sound
