B&W P7
lxd55
44
Cans prior to purchasing p7's:
Grado SR60's - loved them, but only for home usage due to leakage, that in itself was an issue when wife in room trying to watch telly.
sennheiser cx300, got these for travelling to replace iPhone buds. But although in-ears are great for isolation and leakage I wasn't a big fan of in ears ie the fit and the "cleansiness" factors.
So I decided to gun for some high end cans, either on or over ear.
As previously mentioned was closing in on either b&w p5's (style over sound) vs the sennheiser momentum's (sound was better than p5's IMO) definitely with the on-ears. For the over ear momentum's I had issues with the fit, I have quite big lugs and it wasn't the best of fits. So was looking to go with the on ears, cheaper, great sound but I had reservations on the leakage factor, especially with the amount of travel I do (planes, trains etc).
Then b&w released the p7's, much more than I really wanted to pay, but...they fit me superbly, the style is gorgeous (IMO) they can collapse smaller to make it easier to pack, the moe's don't, but what about the sound??
Absolutely stunning, I have a permanent smile when I have them on, the music is almost "3-d" like and totally draws me into it. Great for sound isolation, yes can still hear background noise when on quiet low volumes etc, but crank them up and can't hear anything apart from the sublime music. Note not been on a plane since I got them, which I'm keen to see how they perform. Leakage? Yep there is some, but very very small - not an issue - ie passes the wife test! :)
Do I think they are worth £328? Very subjective, bit like is Gareth bale worth £100m? Probably not, but if that is the going rate then it is what it is.
The acid test has been wife and relatives who have tried them, initial reaction is one of shock re price, but when they try them they are blown away by them (I struggled to get them back off the wife the other evening).
So all in all I'm really happy with them.
Kr
Lxd
dalethorn
2,222
Got the P7. Playing music the bass is strong, but likable - no need for bass reduction like many headphones I've had. The mids remind me slightly of the Beyer DT770LE - in the case of the P7 that's better than the 770LE though. The highs are a bit crispy, so I spent some time with test tones - not as absolutes though - comparing the P7's test tone output to other good headphones, there's a mild peak at 2 khz (no problem), a significant drop at 3 khz (unsure about the effect at this point), back to more-or-less normal from 4 to 8 khz, then a significant peak around 9 khz - again not sure how this peak will pan out, but so far so good, or at least keeping the volume "less than loud" is working for me.
:O
So is it good or bad?
swm_uk
I picked up my P7's from Custom-Cable today.
My momentums have been permanently retired!
what a superb pair of cans :grin:
fr0g
445
philipjohnwright said:
LXD 55 I was born and bred in Heald Green - 2 St Anns Rd Sth to be precise. Spent 20 years there before my parents moved to Cheadle Hulme (where I had gone to school anyway). I go back occasionally, in some ways it's changed, in others not. Still blooming noisy with all the planes!. (apologies to everyone else who won't be remotely interested in this post!) Phil
I worked in Sharston for a while, and went running around Heald Green and other areas in the mornings before I started work. It's a lovely place, or rather it would be but for Manchester Airport, and living so close to some very dodgy areas! :)
I also lived in Handforth for a while and did quite a bit of shopping at JL and Sainsburys....:)
As for the headphones. I would like to hear them, but I really, really, really detest the looks. I'd probably take the Momentums and save the cash :)
dalethorn
2,222
swm_uk said:
I picked up my P7's from Custom-Cable today. My momentums have been permanently retired! what a superb pair of cans :grin:
It really is amazing sound, comfy, and very portable with decent looks.
lxd55
44
Blimey, with the number of forum members with links to Stockport & Heald Green may have to set up a club at this rate! :rofl: Seems to be the trend for members setting up clubs at the moment :)
Hey Frog, would still advise you give the p7's an airing irrespective of looks, you need to check the sound out :grin:
