Question B&W DM604x P6 floorstanders from 1994 an upgrade on Monitor Audio Silver Floorstanders 2005?
Herbhifi
Any views on whether B&W P6 DM604x from 1994 (ones with isolated tweeters) will be better than Monitor Audio Silver from 2005 - someone has offered to swap. Both floorstanders. I think the b&w will be better at more than double the rrp.
I’m pairing with a 50 watt per channel Marantz Cinema 70s. So not masses of power. Biggish room.
I have MND so no opportunity to go and trial. Current Monitor Audio s good but never been bowled over by them.
Tricky.
Only you can decide really.
Where are you getting them from?
Can they bring them around for you to listen to?
I would be very careful concerning the state of the woofers on speakers that old.
Tricky.
They are in mint condition and have never been played really loud. They sounded good when I last listened paired with a Quad 66 setup. You’re right though I think I’m going to have to stick with what I have. They were my dads my mothers partner wants to swap them so he can fit a bigger tv.
