lindsayt said:At what frequency can you no longer tell which speaker the sound is coming from?
I'm sure vlad will remember to do this under 'blind' conditions to stop the knowledge of which one it's coming from skewing the result.
davedotco said:Vladimir said:The CM series is the most coloured, non-neutral, music lover oriented series B&W has ever made. They were made more to be furniture with appeal to non-refined ears, with embedded loudness curve feel. The FR specs are dreadfully, with huge mid-bass humps and upper midrange dips. Moving from that to a fairly neutral 800 series with front ported reflex, the sound may feel really light, to some to an extent sounding like cheap plastic PC speakers.
Move the speakers closer to the back wall to get closer to the original sound you were used to from the CM5s.
BTW I own the CM1s and chose them intentionally over the CM5 because they had less bass, but they still have too much of a hump. I flaten it out in JRiver parametric EQ and get a sound that is less appealing at first listen but more accurate. More midrange details appears as the small woofer is assigned less bass to strugle with and it becomes machinegun super fast.
You get really fast bass from a Kandy and a pair of CMs......*shok*
That is a seriously good trick, that JRiver must be some player.
lindsayt said:Vladimir, try running some test tones through your system. Left channel only, right channel only, both channels together. At 100hz, 80 hz, 60 hz, 50 hz, 40 hz, 30 hz.
Which frequencies, if any, sound identical? Do 50 and 60 hz sound different in your room with your system with your ears? Or do they sound the same?
stevebrock said:davedotco said:Vladimir said:The CM series is the most coloured, non-neutral, music lover oriented series B&W has ever made. They were made more to be furniture with appeal to non-refined ears, with embedded loudness curve feel. The FR specs are dreadfully, with huge mid-bass humps and upper midrange dips. Moving from that to a fairly neutral 800 series with front ported reflex, the sound may feel really light, to some to an extent sounding like cheap plastic PC speakers.
Classic that one Dave 🙂🙂🙂
Vladimir said:stevebrock said:davedotco said:Vladimir said:The CM series is the most coloured, non-neutral, music lover oriented series B&W has ever made. They were made more to be furniture with appeal to non-refined ears, with embedded loudness curve feel. The FR specs are dreadfully, with huge mid-bass humps and upper midrange dips. Moving from that to a fairly neutral 800 series with front ported reflex, the sound may feel really light, to some to an extent sounding like cheap plastic PC speakers.
Maybe if I take the innards from the Kandy and cram them inside the speakers, maybe then Dave would be impressed with my system.
stevebrock said:I doubt it - SS is the problem
Vladimir said:stevebrock said:I doubt it - SS is the problem
Are you an official radical valve convert now Steve? *biggrin* You didn't have problem with SS before IIRC.
What brings more fidelity to the table, moving from SS to valves or moving from passive separates to an active setup?
stevebrock said:Vladimir said:stevebrock said:I doubt it - SS is the problem
Tounge in cheek 🙂
Vladimir said:stevebrock said:Vladimir said:stevebrock said:I doubt it - SS is the problem
Tounge in cheek 🙂
Cool. Seriosly though, your opinion on: What brings more fidelity to the table, moving from SS to valves or moving from passive separates to an active setup?
davedotco said:These are personal views which I suspect are not shared by many on here, but there you are.
Vladimir said:Maybe if I take the innards from the Kandy and cram them inside the speakers, maybe then Dave would be impressed with my system.
Vladimir said:Just look at this sponge supported ribbon cable connected impressive machinery. I can only dream of such quality.
chebby said:Vladimir said:Just look at this sponge supported ribbon cable connected impressive machinery. I can only dream of such quality.
And a dead Persian cat it seems!
Vladimir said:@Dave
Can you point out to these active loudspeakers with valve amplification throughout?
@chebby
I know. I was only joking.
lindsayt said:It's just that I've been wondering if the frequency at which sounds becomes non-directional depends on the room / system / listener, or if there's a single frequency at which it becomes non-directional for all circumstances.
Also I can hear the difference between a 50 hz and 60 hz test tone in my system. Wondering how many other people can too.
Just because the manufacturer of a 50 hz / 60 hz subwoofer says these frequencies sound the same, doesn't mean to say it's true.
And just because a manufacturer of 2.1 systems say bass is non-directional, doesn't mean to say it is at all frequencies covered by their sub-woofers.
davedotco said:Vladimir said:@Dave
I don't think I suggested there were any, though I have no doubt they exist somewhere.
Vladimir said:davedotco said:Vladimir said:@Dave
I can see the future...
steve_1979 said:Several of Quested's more expensive monitors and subwoofers use external amplifiers and crossovers on their active speakers.
