B&W 685 Theatre + ?? AV Receiver
What av receiver would you advise to me for this combination? My nearest dealer has only rotel and yamaha in stock, but what about brands like onkyo, marantz, HK? Music/Movies 50:50. My budget is 600€ max. Thanks for help!
Messiah
tomeq:What av receiver would you advise to me for this combination? My nearest dealer has only rotel and yamaha in stock, but what about brands like onkyo, marantz, HK? Music/Movies 50:50. My budget is 600? max. Thanks for help!
Blimey!
jase fox
212
tomeq:What av receiver would you advise to me for this combination? My nearest dealer has only rotel and yamaha in stock, but what about brands like onkyo, marantz, HK? Music/Movies 50:50. My budget is 600? max. Thanks for help!Get a pioneer as there the dogs bits !!
i run a 685 theater but with 685s front and rear now im running the onkyo 605 at the mo but moving up to the Pioneer SC-LX81 which is a great price at superfi at the mo if you can wait and save up?
I have 684 theatre set up with an Onkyo 806 & the sound is great. I would get an older model such as Onkyo 806 which you should get at a great cost as the 876 is now the new kid on the block & at £600 or (euros) you will get better value for your krona!
Yamaha are great if you can get one :O)
Good luck.
Thanks for all your replies guys. It looks like there is not so hug difference between these combinations. Somebody is happy with Onkyo, somebody with Pioneer... I will try to listen yamaha + B&W and will see... Its my first HIFI and I don't want to go wrong...
Denon 2309 (at under 500) with the 685 theatre (under 1000) works fine for me -once I'd learned how to get Hi def audio running
tomeq:Thanks for all your replies guys. It looks like there is not so hug difference between these combinations. Somebody is happy with Onkyo, somebody with Pioneer... I will try to listen yamaha + B&W and will see... Its my first HIFI and I don't want to go wrong...
I don't think you could go wrong with Yamaha, Denon, Onkyo or Pioneer. All of their current products have been rated either 4 or 5 stars so you really can't make a "mistake".
BTW, I have a Yamaha + B&W combo and I'm also happy with it. :)
