B.K. Gemini 2 ???
beefy
I have just received a Gemini 2 and was woundering can I connect it to my Rotel RA02 amp through the amps 2 pre out socket???
Thanks.
Yes.
But you need two phono leads as the Rotel pre-outs are stereo, not mono like most sub outs.
However the difference will be minimal, use one for know and get the second when you can.
Cheers for the quick reply I have contacted B.K. about only having 1 rcv to rcv lead as their picture on ebay clearly shows 2 and I`ll try What you have suggested tomorrow day when the neighbours are out lol.
