oldric_naubhoff
- Mar 11, 2011
- 23
- 1
- 0
jcbrum said:and the sub has a variable (not simple) low pass filter, controllable both for level and frequency response
actually this is a simple low pass filter for a sub in that way every other sub on the market will be supplied with at least similar solution to help blend the sub with the rest of the spaeker system. variable lowpass filter and gain control are an absolute minimum in a competent sub so as you see AVIs here don't do any extra work over what's required.
some more capable subs would have parametric EQ implemented to help smooth out rooom nodes. some even more capable subs would be DSP controlled in order to virtually eliminate room nodes. this is what could be caled "not simple" xover.
