Aura Evolution Amplifier speaker recommendations
Daithi
I have an early 1990s Rega Planar 2 and Aura Evolution Amplifier with Wharfdale Diamond 8.1SE speakers. Can anyone recommend a speaker upgrade to give a bit more bass? Open to small floorstanding speakers.
First post on here so happy to be redirected to existing threads.
As your question is regarding speakers it might be better if you 're-posted in the main hifi section of the forum.
The Aura is a 'warm' sounding amp, and does not really lack bass...
it can infact sound a bit flabby if you use speakers with poor bass control. I
it sounds absolurely brilliant with my B&W P4's - which are of a transmission line (TL) design, and gives a deep, but dry bass...
PMC makes modern TL design speakers, that would be my first choice for Aura Evo.
Belated thanks for the advice, still got the amp, think Rega Performance Pack upgrade is overdue for the turntable too.
