Right folks need help Omnia sound is not good example vocal is very distant detail is not there this is across optical cd phono and streaming it's almost as if the Omnia were using an internal filter will give an example disturbs sound of silence the background music can be heard over the vocals have checked everything also tried a factory reset have ABed using my rotel power amp then back to Omnia with no difference as said it's pretty much on all inputs even change the optical filter from norm to wide makes no difference
