Audio Delay and Lip Sync - please help
Hi All,
I have a Cyrus AV 8 playing the sound for Marantz DV 7001. The TV via HDMI is Panasonic-TX 32 LXD700.
The system is great but suffers from terrible Lip Sync issues on some DVDs (in particular the TV series 24)! I am looking for an audio delay box, similar to the Felston but for analogue rather than digital. I have searched the forums and the web and can't find anything apart from very expensive bits of kit for recording studios.
Please help. Jack Bauer is much less compelling when his lips are out of sync!
Many thanks,
Tom
I had heard of the Felston you mentioned. Primare do one called a 'Delay Box' Type this in a search engine like google and you will find it for just under 200 pound which is steep. There is another form Alchemy2 called DDL4 and D.DaD think they are two different versions. Not sure if they sell here or abroad though.
All depends what you want to spend, the priamre looks the right thing for you and I think it may have a remote too. good luck
