Oldphrt said:Anyone using the AT95E cart will be blown away by changing the stylus to the 95EX version. It tracks superbly at 2 grammes.
Al ears said:Oldphrt said:Anyone using the AT95E cart will be blown away by changing the stylus to the 95EX version. It tracks superbly at 2 grammes.
Sounds great for the Heavy Metal fans.... ;-)
Oldphrt said:Al ears said:Oldphrt said:Anyone using the AT95E cart will be blown away by changing the stylus to the 95EX version. It tracks superbly at 2 grammes.
Or any other vinyl fans.
Al ears said:Oldphrt said:Al ears said:Oldphrt said:Anyone using the AT95E cart will be blown away by changing the stylus to the 95EX version. It tracks superbly at 2 grammes.
What's new about it? Didn't the old one track at 2 gms?
Oldphrt said:Al ears said:Oldphrt said:Al ears said:Oldphrt said:Anyone using the AT95E cart will be blown away by changing the stylus to the 95EX version. It tracks superbly at 2 grammes.
It did, but not that well on the inner grooves. EX is 0.3 x 0.7mil, E is 0.4 x 0.7. I thought I'd try one as my Grado black needed a stylus and I had the AT lying around. Much better all round than the Grado and no hum!
stereoman said:AT95E tracking at 1.5 vtf. Superb cartridge.
Oldphrt said:stereoman said:AT95E tracking at 1.5 vtf. Superb cartridge.
It doesn't quite track everything at that weight because it isn't an AT440. Have you tried the new EX stylus? Well worth the money. Still needs about 2 grammes though.
stereoman said:Oldphrt said:stereoman said:AT95E tracking at 1.5 vtf. Superb cartridge.
Yes. I spent some time finding out whether really 1.5 vtf is too low and cause more wear than more force. Actually physically only bigger weight will put more wear on LPs. I think low weight is a bit of a myth ? The sound seems great so are you sure it is not tracking everything ? The ranges from 1.5 to 2g sound great with this cart but I think 1.5 to 1.6 sounds the best. I'll try the EX stylus also.
stereoman said:Let us say that as a newbie in TT area - I am currently under big impression from my AT95E cart. The question is , how can a stylus / cart for let us say 200 Euro improve the sound that already is so good. Is there really such a big difference ?
