Hi Fi biker said:
I have a practical question to Big Chris. I can see that you have a PV1 sub. How do you connect that with the monitors and the amp so that everything is in proper phase? I like classical music but I also listen to Chemical Brothers, Faithless and I would like to have more bass when I listen to music like that.
The PV1 comes with it's own speaker level connecting cable, with 4 wires (black, red, green, yellow IIRC). The manual tells you how to connect these up to your amps speaker terminals for correct operation. Plus, the PV1 has a 0/180 phase switch should you need it.
To respond to some of the cables do/don't make a difference posts...
I originally had some £1 per metre generic OFC copper cabling (can't remember the gauge/strand content) which I bought off the roll at a car audio place. When I bought my 602 S3s back in '02, I also got £50 of free speaker cable (Sevenoaks offer). I plumped for the QED S.A Biwire, but didn't use it straight away as I was gonna get it properly terminated with airloc bananas, so I continued to use the generic stuff.
After deciding not to bother getting airlocs fitted (I just bought cheapie screw type bananas off eBay), I substituted the generic stuff for the QED (Had probably been running the B&Ws with the generis stuff for about 3 weeks, with a LOT of use). I perceived an instant change in the presentation. The QED was indeed faster and leaner than my old cable, and these traits remained after continued lengthy use.
A similar thing happened with my interconnects. Originally ran a pair of VDH's 'The Bay' I/Cs (Hefty, bassy sound, but too dull and woolly at the top end), not long after I found some Kimber Silver Streaks on eBay and the price was right, so thought I'd try them. They were much better than the VDHs in almost every area, but they pushed the balance a tad too far in the other direction. Ideally I wanted an I/C with 70% the characteristics of the Kimber, 30% of the VDH.
I ran the Kimbers for about 6/7 years, then with the heavy discounting of Atlas cables (And needing another identical I/C after purchase of my power amp.), I took a gamble on my current Atlas Titans. THIS was the I/C I had been after all along. Neutral, detailed, punchy, balanced, A difference that even my Wife noticed (who usually despairs at all the money I "waste" on bits and bobs for the Hi-Fi).
OK, the Kimbers are Silver (partly), and the Atlas cables are copper, so you may well concede there would be an audible difference, but the VDHs were copper too, and the VDHs and Atlas' are poles apart in their presentation.
I can't explain it, I don't particularly want to. All I know is that these are better. I'm hoping for good things when I connect up my Hypers, but I won't fool myself if there's no improvements. I've got no problem sticking them back on eBay.
I'll be fitting the Hypers this weekend with any luck, and I'll report my findings (after I've run them for a bit), as soon as I can..... A Hyper review minus the hyperbole.
