MUSICRAFT:stpierre76:
Hi rick,
thanks for your reply and interest.Good to see somebody passionate about the product they sell.I am indeed seriously considering swapping speakers but i guess i am a bit stuck in the old way, "if its too good to be true then it is".Also, with hifi, it seems that the more money you spend the better the product is.That may be the case generally, that s 3 products i recently audition and found them far superior to major brands.As such, i use to have a cyrus pre xpd and 8 power, but was not satisfied with the dac.I embarked in a dac hunt and ended auditioning the wyred for sound dac2, plus the matching integrated.I am blown away by this brand in regards to value for money.It leaves the cyrus gear for dead.No disregard to cyrus, it was a great product but...So now i have a little voice at the back of my head that keeps saying the same about speakers.disregard looks and finish,close your eyes and listen to the music.
I am glad you brought up the 20 series as did try and google it, but not much on it.M keen to know more about them and eventually audition them.
What about the atc scm40?Are they quite boomy.In my HT room, i have the focal chorus 826, and did try them in the hifi area, but way too much bass for the room(4m x 4m), which lead me to buy standmounts(electra 1008be).Would the 40 be too much for such a room.?better keep with the 19?
sincerely yours john
Hi John
Your welcome.
I am sorry for not replying sooner as your thread slipped my mind
and i hate to say it but i'll now be tied up for a while so i'll try and respond asap. I am sorry for any inconvenience this has/may cause.
All the best
Rick @ Musicraft
Hi John
Firstly i am truly sorry for my late reply as initially your thread slipping my mind i've also been extremely busy over the last few days.
Anyway your welcome and it is good to hear that you are happy with your new WFS components.
I mentioned ATC's 20 Series monitors because SCM19's monitors also have much in common with them (namely the SLMT mid/bass unit). I feel SCM20's really come in to their own in active form so unless you require new amplification and also want the ability to playback at very high levels then SCM19's will be more then good enough (pretty much regardless of associated components used).
If you can accomodate them then amongst the these three the SCM40's are easily a no brainer. The main reason for this is simply down to SCM40's overall using vastly superior drive units to the ones used in SCM19's/SCM20's such as the original studio Soft Dome mid range unit. The studio Soft Dome is capable of covering a frequency range of 300Hz to around 4kHz and also achieves an exceptionally broad and even dispersion, so the reverberant sooundfield matches the on axis sound which results in a flat frequency response almost anywhere in the room. The LF performance of SCM40's has depth but is also clean and tight. From the many SCM40's which i've sold over the last five years i can't recall hearing of SCM40's LF not being even.
Fwiw, i feel SCM19 monitors are probably the finest VFM standmount designs currently available on the markert regardless of price and SCM40's are overall probably the finest VFM speakers on the markert regardless of desgn or price.
All the best
Rick @ Musicraft
