ATC P1 vs SPA2-150
MattSPL
19
Just wondering does anybody know the difference between these 2 power amps?
Same 150w/ch power handling but a massive price difference and different chassi.
Matt
MattSPL:
Matt
Hi mattspl
While the P1 and SPA2-150 are rated at the same power of 150w/ch however the quality of the SPA2-150's 150 watts are significantly better than the P1's. Therefore the SPA2-150 performs better and drive speakers more effectively than the already superb P1. The fit, finish and build on the SPA2-150 is also better than on the P1.
Btw, the SPA2-150 is one of my favourite power amps and it works a treat with the magnificent ATC's SCA2 pre amplifier.
All the best
Rick @ Musicraft
I am currently setting up a hifi for my office. I looked at the ATC. I actually thought the P1 was a newer version of the SPA2-150 (with its retro looks).
MUSICRAFT said:
MattSPL:Hi mattspl
All the best
Rick @ Musicraft
Dear Rick @ Musicraft,
I'm planing to buy either ATC P1 or SPA2-150 power amplifiers. I don't know which one to choose? (I don't have a chance to try before buying)
You say latter performs better, in which way?:
soundstage (wide-deep)
image stability (small-big)
musicality (clinical or warm)
tonality (percusion-string instruments)
treble extension-bass control
Spk: HarbethM401
Pre:Audio Research LS17
