- Jun 15, 2011
- 31
- 0
- 0
1. from cd transport to dac
2. from dac to preamp
3. from preamp to amplifier
4. from amplifier to speakers
abacus said:Providing you use quality cables it will not make any difference, however the shorter you can have them the easier they are to run and hide.
Don’t pay any more than £10 for a 1m signal cable and £2-3 per meter on speaker cable, as you will just be wasting your money.
Hope this helps
Bill
andyjm said:The most important leads to keep short are amp to speaker. This is where cable resistance has the bigest effect.
As a general rule, a short lead is a good lead, but in the case of a coax cable used to carry S/PDIF from CDP to DAC, there is a school of thought that suggests the lead should be longer than 1.5M.
For those with an engineering bent who remember their transmission line theory, the argument revolves around the impedance mistmatch of the 75ohm coax with the (usual) RCA connectors and the resulting signal reflections.
Covenanter said:andyjm said:The most important leads to keep short are amp to speaker. This is where cable resistance has the bigest effect.
Baloney! The most vulnerable part of any system is the front end. Any distortion/interference introduced at the front will be amplified (that's what an amplifier does to the input signal lol) and will affect what you hear the most. Speaker cables are largely irrelevant. The previous poster who I have quoted knows as much about physics as I do about Rumanian folk dancing! (I do have an engineering bent as my first degree wa in Electronics. lol)
Chris
krolikgena said:andyjm said:The most important leads to keep short are amp to speaker. This is where cable resistance has the bigest effect.
Finally someoe has related to my post.. Thank you
My xlr's are 3m each from preamp to mono amps.. i just thought maybe it's too long distance for a signal to travel and i should change it for 2m?
But in traditional hi-fi setup the cables are short between all boxes and long aaaall the way to passive speakers
Alears said:krolikgena said:andyjm said:The most important leads to keep short are amp to speaker. This is where cable resistance has the bigest effect.
XLR connections are ideal for the longer cable runs associated with the music industry, and I mean long.
3m is not long. You will hear no difference if you replace it with the same at 2m length.
I am not sure all this talk of RCA connectors is at all relevant.
Overdose said:To andyjm,
5m of copper speaker wire of 2.5mm with have a resistance of approximately 0.017092 ohms
10m of copper speaker wire of 2.5mm with have a resistance of approximately 0.03418 ohms
I don't personally consider this amount of resistance as particulary significant in any part of the audio chain downstream of the sources.
krolikgena said:abacus said:Providing you use quality cables it will not make any difference, however the shorter you can have them the easier they are to run and hide.
Hope this helps
Bill
I've already spent £500 on Tellurium XLR.. :wall:
Alears said:............ and that is why they make 110ohm coax SPDIF cables
andyjm said:Overdose said:To andyjm,
Hmmn. You must have got your EE degree at the same place Chris Covenanter did.
I calc 5M of 2.5mm^2 copper cable at 0.034 ohms, or 0.068 ohms for the round trip.
My Martin Logan's impedance curve dips to a low of 1 ohm, so we are talking about 6.8% of 'voicecoil'. Doubling this to 10M gets the speaker cable to approximately 14% of 'voicecoil' impedance.
That sort of feels significant.
